Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281вопросов Показать все
No sign of power on MacBook 2015 Core M.
My MacBook 2015 randomly died and then wouldn’t charge. I removed the back panel, tested the cells and they were reading below 2.9v. I have since removed the battery and installed a brand new one, but there is still no sign of life. I have plugged the MacBook in with a 5W charger as suggested in the iFixit guide, but after a few hours still nothing. LogicBoard Issue??
Это хороший вопрос?
Оценка 3
Добавить комментарий
1 ответ
Have you gone in with a multimeter and tested for continuity between the power switch, the battery, and the charge port? Im not too well-versed with how the board is wired up in these models, but I would recommend checking to make sure that the battery is even being recognized.
if it’s anything like the chromebooks that I fix daily as a result of my job, I would recommend just charging it all night long and coming back in the morning. Some of the batteries come almost dead and as a result take a day or two to regain their composure so to speak.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Hi Shy, thanks for your response. I haven't checked continuity for the power button, as I never thought of that to be the issue. I will check that now. Although when the Mac has reached a sufficient charge it should switch itself on which it hasn't done. I have checked the new battery after leaving it on charge for a while, and the cells show 3.6v, so the Mac should be powering on.
из
Добавьте свой ответ
Donald будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 399
