Why does my Mac say there no wifi hardware found? done reset.
No wifi hardware found , after woke from sleep , done reset SMC and NVRAM , error after hardware check is CNW001
Это хороший вопрос?
Это хороший вопрос?
Hello Alan!
First of all we must exclude a software issue. First, try to boot your Mac into the Safe Mode (press and hold the shift key immediately after pressing the power button to turn on your Mac).
If the issue persists, try to load your system from the external drive with known good system. Or, reinstall the system, using the newest available software your system supports.
If the issue persists, it’s related to the hardware part. The device doesn’t have detachable AirPort card like the MacBook Pro’s. The WiFi module is soldered to the logic board. So, in most cases the logic board should be replaced, but maybe you’ll find a good service center which will fix this logic board for reasonable price.
Был ли этот ответ полезен?
Just order a logicboard replacement that's tested
Worth it only macbook left that let's you remove the hard drive! After 2015 model your data is kept in the arms of apple they solder everything down even your hard
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 636
