First generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
146 Questions Показать все
What went wrong? iPad Mini 1 Digitizer Replacement
Hey. Last summer I got the chance to repair an iPad mini I got for free. Everything was working except the glass was cracked. I replaced the digitizer all good, no issues but at then I realised that the screen was not stuck down properly as the adhesive was weak. I proceeded to put very thin double sided tape on the corners of the iPad. I put a stack of large books on the back of the iPad and laid it down face down but then when I turned it back on there were lines on the LCD. Was just wondering what has gone wrong as I want to start repairing iPads now as I have repaired lots of iPhones now.
Thanks!
Add a comment
Android Fix Kits
A new screen or battery is one kit away.
Купить сейчас
Android Fix Kits
Купить сейчас
1 ответ
Chosen Solution
It sounds like you damaged your LCD. Lots of pressure can damage phone or tablet LCD’s, especially when it is applied for long periods of time. Tablets especially are susceptible to LCD damage as their digitizers are too large and thin to provide much support against anything pressing on it.
It is also possible that your LCD connector dislodged slightly, which is a common problem among iPads. You could start by giving it a solid smack on the back casing, right in the area of the connectors. If that doesn’t work you could try going in again and double checking to make sure the connectors are firmly seated.
Hope this helps!
Score 2
Add a comment
Add your answer
Rafay Siddiqui will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 14
