iPhone XS Max restarts every 4 minutes after screen replacement
I have an iPhone XS Max that appeared fine after a screen replacement. The screen is aftermarket, and the phone now restarts every 4 minutes. Everything seems to work fine in those 4 minutes, battery charged, cameras work, touch works, receives texts, makes calls. Is it just a bad screen? Already tried updating all of the apps and even restored the phone. I have the phone coming back in and will put the original back on to see if that fixes it. Any ideas?
Это хороший вопрос?
7 Комментариев
update: phone came back in and original screen did not fix the problem. Have tried to restore again, and use TenorShare to fix any issues software wise. Still no luck.
из matt mocciola
Any update on this issue?
из sahilakhan8130
Still no updates or answers from anyone
из matt mocciola
Welcome to the modern times of aftermarket screen replacements.
из Alex Robinson
Hey Matt,
I used to work for Apple and am assuming you did the screen replacement at a place that wasn't through Apple. You mentioned you already got the original screen back on which didn't help to fix the restarting issue. Is that phone still under the original 1 year warranty through apple? I assume that you didn't get Apple care otherwise you would have done the screen replacement through them?
из 2Sarcastic4U
Показать 2 больше комментариев
