Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
43вопросов Показать все
How do I change the power button?
A couple of years ago, my phone fell and hit the floor. Since then, the power button on the left does not work - I can push it, but it’s like there’s not contact, holding down the power button does not start/turn off the phone. I’ve been using the power+volume down+middle button ever since and was wondering if my issue could be resolved.
Thanks for your suggestions!
Michal
Это хороший вопрос?
Оценка 4
Добавить комментарий
1 ответ
Наиболее полезный ответ
The power button replacement is possible for this device. It’s a bit tricky to complete without soldering experience. Here is a teardown guide on how to open the device and remove the logic board.
Once completed, the power button can be de-soldered and a new one attached to the logic board. Here is what the replacement part looks like. The process is very similar to the Samsung Galaxy S4 power button replacement.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
zemkom будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 639
