The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
115вопросов Показать все
Benz power steering pump and bracket
The mounting bolts on the power steering bracket and pump have fallen out. It seems like maybe one loose hidden bolt is still holding . What needs to be removed to get the pump out so the pump bracket can be refastened? 76 4 cyl diesel automatic
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Is your similar to this one? Only first 15 minutes.
https://www.youtube.com/watch?v=VDDLhf4m...
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
This car isn’t the same as mine, however I see that I should just plan on removing the items that are in the way. There is no shortcut to getting the pump and bracket out. Very good job on making the video.
из
Добавьте свой ответ
Gene Steele будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 49
