@gammanumeric the Apple Cinema HD display should work on any system that has a DVI-D port. For the 30" and the 27" you will need a dual-link DVI-D port to be able to use the full resolution. You may run into some issues like not having full capable resolution, brightness control etc. since you will need an appropriate driver for this monitor, but it should not prevent your monitor from at least turning on.
Power
Power switch or brightness button not working
2. Check connector J4 at the main board. Reseat the cable at the main board and at the touch switch board.
3. Replace the touch switch cable.
4. Replace the right end cap that includes the touch switch board.
No power
1. Check the wattage that is printed on the power adapter. See the table below to verify that the power adapter shows the correct power rating for this display. (For more information, refer to Knowledge Base article 86800.)
2. Use a known-good power adapter, and check all cable connections.
Let us know what you find on your power adapter and let us know once you get your DVI setup.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
5 Комментариев
What is your mac system? That would help in knowing.
из Dan
I use a PC and my system doesn’t matter because I have no way of connecting it yet (Lenovo Y740-17Ichg)
из Gregor
SIERRA Display shows in start up but not for desktop alternate monitor shows Desktop
из worldstudios
After freaking out I finally fixed it by unplugging the USB cable from the dvi to power block. But monitor still requires DVI /, USB to Mac to be plugged in .. now I have to leave that USB unplugged. So if your is not working play with unplugging the various USB connections.
из prometheustrotsky
I've had a similar issue, that I have an Apple Cinema Display (A1083) and I got power supply (A1093) from ebay, but when I plug it into the wall (no connection to my computer), I don't see any signs of life, even when I press and hold the power button. When I plug in the USB to my computer, still no signs of life in the monitor. I've tried unplugging the connections to the power box.
Any thoughts on what I can try next?
из jenkinssahline
