Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Вопросов 216 Показать все
Missing socket for WiFi antenna cable from iPad Air 2
While prying off old antennae cable from socket during WIFI antennae replacement of iPad Air 2, socket was accidentally removed from board. Is there a replacement part of some way to fix this?
Это хороший вопрос?
Оценка 1
1 Комментарий
Could you add a picture or two?
из
Добавить комментарий
Ответов (3)
Выбранное решение
There are really two options for this:
  • Order a replacement iPex antenna socket and attempt to solder the replacement to the logic board (I would order a wifi card with the same socket and transfer the connector)
  • Strip back the antenna wires and solder them directly to the logic board.
Был ли этот ответ полезен?
Оценка 1
Thank you so much for this!
Оценка 0
1 Комментарий:
I’m having a hard time finding a replacement SOCKET for this. I’m only finding the same piece I’ve already replaced ‘WIFI antenna and GPS ANTENNA FLEX CABLE REPLACEMENT’ which does not include the socket. Do you have any suggestions? Do you have any videos on soldering the wires to the board directly (missing socket)?
из
I haven’t had success downloading a pic to share.
Оценка 0
Добавьте свой ответ
Mary Jo Webb будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 138
