Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
87вопросов Показать все
Can I upgrade myself SSD on 2019 MBP 15?
Just bought a 2019 15” MBP with 256 GB SSD. (On sale in Costco, not configurable).
Can I replace it with my older 500 GB SSD from my previous MBP?
If the answer is yes, anyone knows it it would it void Apple’s warranty?
Thanks in advance for your help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Sorry, no you can’t swap out your SSD’s. While your 2015 or older Retina model has a removable SSD, the newer 2016 onward Touch Bar systems have soldered storage which can’t be altered.
But! you can remove your old systems SSD and place it within a case to use it as an external drive. That might be useful if your older system has died and not repairable OWC Envoy Pro - Portable, Bus-Powered USB 3.0 Storage Enclosurefor select Apple Flash SSDs from most 2013 to 2015 Mac Models
If you are trying to copy off your stuff to your new system there are other ways to do that YouTube - Using Apple Migration Assistant
Был ли этот ответ полезен?
Оценка 6
1 Комментарий:
Thank you Dan for your answer.
Appreciate it very much!
из
Добавьте свой ответ
Saul будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 22
За последние 30 дней: 115
За всё время: 27,006
