Released in 2010; identified by model P05G. This laptop features a 13" display, solid state drive, and integrated Intel HD graphics.
4вопросов Показать все
How to upgrde this laptop with gtx1660ti ,8gb ram and 2tb ssd.?
I want to upgrade my laptop (Dell latitude E4310) with 2tb ssd,8gb ram and gtx1660ti.
can I do it?how to upgrade this laptop with thtis specifications(2TB SSD,8GB RAM,GTX1660ti)?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @aslam44 ,
You can upgrade the RAM to 8GB as the laptop has two memory slots that can each handle 4GB PC3 8500 RAM modules.
You can replace the HDD with an SSD. Here’s a video that shows how to do it.
You cannot upgrade the GPU as it is hard mounted onto the motherboard.
Here’s a link to the service manual for the laptop which may help with the replacement of the RAM and the HDD
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
thank you very much..
из
i want to use an external gpu for my laptop..
из
Would be cheaper if you bought a Ryzen 5 Laptop with a GTX graphics.
из
As already mentioned by jayeff, the ram and storage upgrades are very much possible. You can choose to buy an eGPU device to use your graphics card with the laptop, but I wouldn’t recommend this unless you already own the card and have $40-50 to spare. The eGPU adapters can connect with Expresscard or mPCIe, but either one will work okay. Of course, your graphics card will be slowed down by the single PCIe lane and the i5 M 560 CPU, but it is certainly possible. In short, yes you can, but you would probably be better off buying a newer laptop for the same amount.
Оценка 0
Добавьте свой ответ
Arif Hossain Aslam будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 422
