No boot or random boot
Hello
My daughter’s MacBook Air is showing a heavy trouble.
History: I bought this computer in August this year to someone who seems very cautious with devices (packaging box with all accessories including screen original plastic protection). And it never showed any trouble.
Last Sunday my daughter told me: The system doesn’t start. The MagSafe led was Green. The power key button didn’t have any action, no light, no sound.
I tried with keyboard the NVRAM reset, and the SMC reset. No reaction except that the MagSafe LED stopped to be lit, LED went off. Same with long press on power key
Then I opened the system and disconnected the battery, tried to power it without adaptor and battery to reset SMC. After battery reconnected same state - Dead.
I also tried to boot without battery and adaptor - Nothing.
I have cleaned with air and brush the visible side of motherboard without noticing any damage. The onewire pin solder on the magsafe connector is not shinny but i don’t know if it is a trouble with ROHS soldering requirement.
The system was stone dead. I’ll tried pressing many keys on keyboard. So I decided to look for schematic on my other computer leaving the adapter connected on the system Suddenly the system booted by itself and the MagSafe LED was green… (about 15 minutes)
I was able to log and works fine without any reason to think about a software corruption. I saved the essential data on USB stick and all was normal. The battery was showing 100% of charge. I turned off the system and then... Dead with MagSafe LED Green.
After a short period of very dead sleep, the system booted alone once again…
I tried a NVRAM reset with terminal and reboot - OK
I tried the power key button - OK
I turned off the system, it was able to boot.
I updated the OS: it reboots several times and I was able to turned it off and reboot.
Then I decided that it was saved and I put back the screw on bottom cover and now the system is dead again!
Please Help!!
Note: is the back cover necessary of electrical test? There are three contact pin on each side of the board that are to be pushed by cover ?
Thank You
Update (10/22/2019)
Here’s a picture of battery health.
The system has been working perfectly for last 4 days, and now it stop working again.
It seems that the MagSafe board has been « touch before » could this be a track ?
Это хороший вопрос?
2 Комментариев
This morning the mac booted normally... i let it working on battery to see..
Note: no drop or water spill to report.
из philippe
Lets check the battery using this gem of an app CoconutBattery Post a snapshot of the main window and post it here Adding images to an existing question
из Dan
