Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1202вопросов Показать все
How to solder a power button switch to a laptop motherboard
ok so i have a 2007 macbook motherboard im gonna use it with a portable monitor so one thing i dont have a power button and some ppl said to me to solder a switch/button on the motherboard but i dont know where to solder one but thanks i appricaite the help
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
For this model I believe the power on pads (marked with a power icon) are located below the fan:
You can just solder a basic button & two wires to those and you’re set.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
ok i never did this before lol so where could i get wires and what color could i use wires from a phone charger so lol im just trying to understand this correctly ok so i need wires and a button and then i need to solder the wires to the motherboard and then to the button and im all set
из
I'm just thinking you get a [button like this](https://www.amazon.com/Twidec-Normal-Mom...) and attach each wire to a pad. A bit pricey, too bad RadioShack went out of business lol — you've gotta be careful though, make sure you don't short out anything else on the board, it's small stuff you're working with.
из
@jonaharagon ok where does the red and black wire go on the pads or does it matter which side and also what side on the switch thanks
из
Добавьте свой ответ
Kenneth shawn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 833
