Model A1625. 2015 revision to Apple's set-top-box featuring an A8 processor and 2 GB of RAM.
30вопросов Показать все
Replacing the wifi chip in my Apple TV 4
Hi,
My Apple TV 4 has a defective bluetooth/wifi chip. So I found one on eBay, a 339S00045 chip, which seems to be the same as in the ipad mini and pro. I took my apple tv apart, but the chip doesn’t seem to be that easy to replace. Is that something that is even possible at this point?
Regards,
Pieltre
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sadly this is a BGA chip which really needs a proper rework station to fix.
Basically, after you carefully remove the old chip you would clean the old solder off clean the board and then using a mask and the correct sized solder balls layout the field and then reflow the chip back on.
Given the cost of the needed equipment and sundries. I think it will be cheaper just getting a new Apple TV ;-{
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jean Maxime Lachance будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 508
