6th generation of Motorola's Moto G line. This phone was released in 2018 and features a glass back that is easier to remove than Samsung phones. Model numbers are XT1925-4, XT1925-5, XT1925-6, XT1925-12 and XT1925DL.
34вопросов Показать все
How do I repair the microphone
This for Motorola G6 1925-6 how can I replace none working microphone that is definitely not working
Это хороший вопрос?
Оценка 1
1 Комментарий
My microphone has also failed - I am wondering, is it a single component or, do you need to replace the whole motherboard ... and is it worth it? Better off buying a refurbished phone? Thank you.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
To be clear, because is a lot of confusion between microphone and speakers, microphones are a input device, if nobody can hear you is a microphone problem. Speakers are output devices, if you can’t hear is a speaker problem.
Microphones in this model are attached to the motherboard with soldering balls, and you need a soldering equipment to do the job.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I was clear - the microphone does not work - no one can hear me (but I can hear them.)
Thank you for the information.
I do not believe the phone is worth the cost and difficulty of repair.
из
Добавьте свой ответ
Carl jones будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 452
