94 xjs 2+2 Warm starting problem
Starts fine when cold but when warmed up it needs to crank a long time before starting but then runs fine. I replaced the front pressure regulator and injectors and it had no affect on it starting when warmed up. Otherwise the car runs great. What can I check next?
Это хороший вопрос?
Оценка 0
2 Комментариев:
Try checking your crank angle sensor, they are known to work great cold but stall out engine when hot.
из
Never stalls out just hard to start
из
Добавить комментарий
