The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
167вопросов Показать все
changed the screen of samsung s8+ but the phone isn't turning on
the phone was in a bad condition when I got it (smashed screen) so I decided to change the screen + the frame, ordered service pack and I got finished to move every component to the new frame.
however, the phone is still not turning on.
when I plug it to the battery, it vibrate once. still nothing. when I plug it to my computer it wont recognize it.
I struggled a bit with the vibrator motor when I took it off from the smashed screen… maybe it’s faking the vibrate and I need to change the battery?
Это хороший вопрос?
Оценка 2
2 Комментариев
Do you have the wireless charging coil installed? This is part of the black plastic mid frame that clips into the metal housing and on top of logic board.
из
I do, I thought that was the problem so I installed it but it's still doing the same weird vibration and not turning on
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@tom9 always have a plan when trying to repair devices you have no history on. Something Like the Samsung flowchart would be a good way to start. That way your troubleshooting is organized and not all over the place :-)
Right above U7002
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Bro, that flowchart file is amazing! Could I please ask where you got it from? Any chance you could share the full document please? Many thanks in advance! :D
из
@Felipe Leal contact me by email. Address in my profile. Just click on my avatar.
из
It’s either that the battery is screwed and needs replacing, when you were replacing the screen you may of damaged the main circut board, or that the previous owner has done something to the phone that has caused such damage to occur. that’s either caused by an extreme impact or some accident that has something to do with liquid as damage can compromise the waterproofing.
I hope this is helpful! :-)
Оценка 1
2 Комментариев:
I'm planning to change the battery and update if there's any change
If it's not helping, I can assume the board is damaged?
из
@tom9 yep, if it doesn't show any sign of life after replacing the battery, there may be either something wrong with the circut board or a critical piece of hardware has failed
из
Добавьте свой ответ
Tom Doe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 544
