The Cruzer Blade is a USB 2.0 flash drive released by SanDisk.
8вопросов Показать все
Write protected pendrive issue
my pen drive has been write protected, format related issue.
I did everything like in registry edit, cmd command, used tools, but the problem remains same
Это хороший вопрос?
Оценка 14
2 Комментариев
Have you attempted to use any kind of write protection removal or partitioning tools?
из
usb write protected problem
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
First I maked the bootable USB of Ubuntu then I installed Ubuntu in dual boot successfully, but now I am formatting my SanDisk USB then it is showing me error of " write protected". I tryed most of the ways from Google but that is not working, my USB is also showing in disk manager but, I am not able to format or delete the partition, can you help me please 😢🙏
Был ли этот ответ полезен?
Оценка 2
Sadly there just isn’t any way to salvage your USB drive.
Оценка 1
Download Ease partition primary
And click own write protection clean
It will scan usb and clean its write protection problem
Оценка 1
Possible causes of read-only mount:
  • Security configurations on the Operating System; Too many to list, but they are altered using Windows Registry; Google around;
  • Corrupt Filesystem / Dirty Bit set; Use chkdsk;
  • Corrupt partition table; Use a drive partitioning utility; Pendrive will be erased but will be usable later;
  • Pen drive microcontroller reporting faults; It means it’s time to buy a new drive. I’m still looking into possible temporary fixes to make the drive last a few more days, but it looks bad.
Оценка 0
1 Комментарий:
из
Its seems that Cruzer Blade usb disk is awful. I have the same problem “write protected” and I have found many other posts in internet with the same problematic usb disk.
Оценка 0
Добавьте свой ответ
Rohit Dharan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 23
За последние 30 дней: 110
За всё время: 4,512
