I know this is old but I wanted to give more of a complete answer.
1st check if the laser moves when the lid closes or first powered on. If it don't move then most likely it is the two switches that detect when the lid is closed. The one in the back side of the system near the middle is common to have issues, soldering a wire from one side to the other will work well and I have done it several times.
2nd we should beable to rule out the switches so now the question is, has the system been worked on before. If it has, the ribbon cable for the motor that spins the disk is common to get messed up where it plugs in.
3rd If everything appears to be working correctly but the disk won't spin, try a CD in it. It is very common that the cause is that the system don't "see" a disk in the drive and most common media is DVD so that is what wears out. If it reads the CD fine, then most likely it is the laser.
4th Just to note as above, there is a small break for the disks and if that is not released when the lid is shut, it will have problems reading the disk, but it WILL spin still.
5th Once I had a "worm" motor go bad that moves the laser. The case I had it would see the disk but would not read it. Found the laser didn't move at all. When the system is turned on or the lid is shut, the laser should always move to the center of the disk and a small switch is pressed so the system knows where the laser is at. Also the switch can go bad and continually try to move to laser to the center causing a clicking notice that don't go away until you shut it off.
Hopefully this can help answer some questions for the readers of this question and point them in the correct direction.
Source: Fixed and modded PS2s for over 5 years
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
8
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
4 Комментариев
hi I have a ps2 slim I still like to use for guitar hero but it wont spin or read and lazor does nothing everything is connected but the ribbion on the optical lazor lens was torn so I took one from a dvd player same with cud that b the problem it comes on jus fine and I check all the switches and still wont spin or read please respond asap so I know what I gotta order to fix it
из dlipe1988
hi i have a problem with my ps2. my ps2 is really old 8 years. at first 1-3 yrs ago it works fine but a little difficult to turn the game on because if fail sometimes and 4-7 yrs ago it's now really difficult to turn the game on i kept restarting it like the game plays at 15%. And now in 8 yrs it now didn't work to turn on the ps2 so i got a major problem, I know my PS2 is very old but is there any idea what to replace it with? My email is rapha_raphael54@yahoo.com so please send me a message thanks you.
из op2nd
hi bro my ps2 model is SCPH 90001 and my dad bought it around 2008 maybe and i havent touch it since back then , and now ive decided to use it to play and it appears on screen " the red screen" which says insert playstation format disc .. jow can i resolve that, my neighbor says that my ps2 needs to be modified... i dont know what to do bro pls help.. hoping for your answer btw my ps2 is slim
из ron jason
Hi my PlayStation 2 is not showing on my T.V wat should I do
из Emmanuel Daniel
