Not sure what you'd call this (Post attempt #3)
3nd time posting this because for some reason the last 2 posts were marked as “innapropriate” and deleted.
A long time ago, my PS3 model CECHE01 stopped transmitting video to any TV. Recently, me and my brother have tried to fix it. Here’s the symptoms:
- The PS3 turns on with a green light, but no video is displayed.
- The only thing that will display is the safe mode menu.
- When we insert a disc into the drive, the blue light will turn on.
- Controllers can be plugged in and charged.
And here’s what we’ve tried:
- Resetting the settings. Safe mode does appear, but when we hit an option, it stops transmitting video again.
- Blowing any dust out of the system with compressed air.
- Other options in the safe mode menu. The only other one we’ve tried so far is “Restore File System,” or whatever it’s called.
- Using AV and HDMI. Neither video output worked.
Any idea as to what to do next?
Это хороший вопрос?
Not sure what I did differently, but it's not marked as innapropriate this time! Hooray!
из Firstname Lastname
@sc00tin double checked your previous attempts and could not see anything wrong with it. I removed the prior two attempts in a way that reversed the penalties on your reputation.
Now, let's see if anyone can help you with that. @tronicsfix is the console guru on here so let's see if he can help you out.
из oldturkey03
Wish I could help but I don't know much about the older systems. Sorry
из TronicsFix
