Aftermarket power adapter advice
I lost my original charger on a trip so I need to get a new one. Found a brand called Topnma making a non-branded but identical charger with same wattage and volts/amps rating. Can I trust it?
Это хороший вопрос?
Это хороший вопрос?
Hi Goodman 4525
In general it should works, but it might not be properly designed like the original, e.g. short circuit protection, safety features, etc.
I know some cheap adapters, either that, output voltages can be “dirty” alot of noises, which is no good for your laptop.
cheap adapters normally efficiency and safety are always a concern.
perhaps you can save some money, but no one knows on the long run if it can harm your computer.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 71
1 Комментарий
If you can wait to buy a proper charger I would hold off buying that. There's always a risk of the charger going bad and killing the laptop.
из Ben
