WiFi Connection drops randomly
The WiFi keeps dropping signal for 5-10 seconds and then reconnects all by itself. I watched it do it in the connection status tab under network, in the settings. I Know it’s an issue with the PS4 because my Roku in the bedroom will still play Netflix at the same time that Netflix on the PS4 stops playing due to no connection. I also tested it with my sisters PS4 on the same WiFi. I went under the Connection Status tab on hers, and watched it for about 2 minutes. It never once dropped. Hooked mine up in the same exact spot, and watched it and at first it didn’t drop. But then I went and played COD to put the WiFi under stress. 60 seconds into playing COD the connection dropped. Went and look at the connection status and sure enough it would drop for 5-10 seconds and then come back. The controllers never disconnect like I’ve seen some people complain about so I dont Know if the problem is the antenna or the WiFi chip. Does anyone know?
Это хороший вопрос?
We seem to be having the same issue here. The PS4 is connected via Ethernet. My iPhone and iPad are not able to connect at all when the PS4 is on whereas my boyfriend Samsung phone’s connection is working fine over the same WiFi.
[br]
We changed our apartment settings recently, the PS4 was connected via Ethernet through a power line adapter and all other devices where working fine using the Main WiFi.
из camille.fisichella
My old ps4 worked great. I upgraded to the ps4 pro and my wifi kept dropping. Even though it was only 10 feet away from the router. So I extended a lan cat 5 cable to hardwire the ps4 pro from the router… And I'm still getting the intermittent lost connection message, only now It reads my lan connection has been lost. I'd upgrade the router if the rest of my house or tech was having issues but roku and firesticks and cellphones never lose connection.
Mad and frustrated that there doesn't seem to be an official answer addressing this as many people seem to have this issue.
Any answers out there?
из Sin Eater
basically, I'm being disconnected from PSN every 10-30 minutes now for the past 3 weeks. I've swapped to LAN cable.. upgraded my router.. swapped out ethernet cables (though the disconnects happen with wifi as well) but like other people are stating the disconnects don't seem to be affecting any other devices in our home... even swapped to the optimal DNS servers.. the only "fix" I've been able to find is going to network settings and "testing connection" this seems to buy me about 30 minutes of play.. any answers or solutions offered would be greatly appreciated.
из xanhammar
Glad to know I'm not the only one! My PS4 is constantly losing the connection no matter if it's connected wireless or ethernet cable. It's incredibly frustrating!
из Dannik D
Same here... Getting Very Frustrating! I’ve tried all the fixes, still dropping. The network testing connection buts a little time, from what I understand is a reboot of the PS4 wireless.
из Lance Biggs
Показать 8 больше комментариев
