Why is turn signal clicking noise coming from gear selector now?
When my 1995 Pathfinder is in park, without my foot on the brake, I turned on my turning signal and I get the normal turn signal clicking from dash but also by my right leg in gear shift selector. Once I press my foot on the brake, the clicking stops at gear selector. Was just curious what cause this, as it only happens when truck is in park without brake pedal pressed
Это хороший вопрос?
This sounds like a bad ground wire broken in the ground that is shared by both the turn signal and the gear shift solenoid. Lets look for a wire diagram and see if they share a common ground someplace?
из Duane Donaldson
Hi @ Duane Donaldson,
Here's a link that may help ;-)
из jayeff
