Bad network signal on original network card.
The original network card in my MacBook Pro Early 2011 13” does not seem to have great network range. I have tried reseating the connectors on the network board with no success. Any help would be appreciated.
Это хороший вопрос?
2 Комментариев
Can you give us some background here. What happened that made the WiFi signal hard to pick up. Did you move the WiFi router or change it out? Did you bang your system or get it wet?
из Dan
@danj The system has been used normally by a family member since date of purchase, and one day, it just stopped working. It wouldn't have been water damage as there is zero corrosion anywhere, but a drop could be likely. I'm just looking into what parts might need replacing if I wanted to.
из Joshua Lockett
