Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2261вопросов Показать все
Microphone doesn’t work
My iPhone 7 doesn’t have a working microphone, no sound during video. Alexa in Amazon Alexa app turns on for split sec before it’s gone. when I try to use Siri it activates but it doesn’t hear anything, nor will the voice recorder start.
But when I connect my Bluetooth earbuds ( cheap onn earbuds with mic I think) Siri activated and it can hear me and voice recorder works, but when I record video there’s a greyed out slashed speaker symbol at the bottom. Alexa starts but only turns on for split sec.
also when I try to use lightning port to aux or the apple port earbuds , there’s no sound nor do volume buttons work
pls help
Это хороший вопрос?
Оценка 0
1 Комментарий
A guy at a repair place said it is a software issue, but I’m not sure. I’d like to know first because I really don’t want to have to reset my phone. But if I have to, could I back it up and then restore it from the backup. Could that work?
из
Добавить комментарий
1 ответ
Выбранное решение
When you do calls is the speaker icon greyed out and can't be switched on? Does the phone take like 5 minutes to boot up all the time?
If yes to both it is an audio IC chip fault on the logic board. There are a few pads under the chip that get loose that need to be fixed which connect it to the logic board.
A local reputable phone repair shop that does microsoldering can get this fixed for you.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Yes, the speaker is sometimes greyed out, the phone used to take 5 min to boot up( it’s the boot loop virus) a restore fixed it
из
Yeah that is the solder balls under audio IC getting intermittently loose.
из
Добавьте свой ответ
Brayden S будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,743
