The Dell 1710n is an office laser printer released in 2011.
How to remove white 'scuff'marks on print jobs?
Had no problem until this week - my 1710 printer is not printing clearly, there are scuff marks that repeat in 'white cloud' shapes down the page in regular intervals. I have pulled out the printer catridge etc and have wiped out excess toner internally via the front panel. Is this problem caused by a piece of paper stuck on the rollers ?? The dell toner cartridge is hardly used, as new.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
This is generally due to a scratch in the drum unit. Sometimes light damage, but it's very often that the drum got scratched at some point. Take the drum out and inspect it for damage.,
In almost every case, light damage is permanent. I have had to condemn two drums for light damage ghosting on Lexmark machines because I got them used from sellers who left the drum out too long. Sometimes, they recover if you refrain from use for a bit, but very often, the damage is done. Other times, it might be recoverable, but the drum is already well run, so the odds of recovering aren't great. If the drum is cheap or you have one ready, replace it and move on.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Johanna буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 37
За всё время: 1,370
