Can you remove the up/down arrow keys on the MBP 16" 2019? Solved
Is it possible to remove the up/down keys in particular?
I was having issues with the down-button where it sometimes wouldn’t press. I assumed something was stuck under the key, so I plucked it out. Now it doesn’t seem to want to go back to its place. I can get it into place on right side of the button, but the left remains lose and you can lift it up.
In trying to debug and figure out how the button’s placed, I also removed the up-arrow key and now I’m having the same issue with that button, except in reverse. The left side gets snapped into place but the right side of the button remains lose and you can lift it up and play with it
Image attached
So my question is: Have I in fact broken the keys and are they not actually possible to remove? Or am I just doing this wrong? How do I snap them back into place? I’ve tried removing the white butterfly underneath and tried snapping it onto the button but I can’t get the butterfly to stick to the key on both sides, one of the sides just keep remaining lose
Any help would be incredibly appreciated
Tyvm in advance
Это хороший вопрос?
6 Комментариев
I have the same problem. Were you able to fix it?
из piotr
I returned it to the Apple Store and they looked at it and repaired it within a few minutes for free. I don't know if that's because I have Apple Care but that's how I fixed it
It turned out I had broken it. It should be possible to remove the keys but you have to be careful. You can either replace the key or, like in my case, the guy fixed the key itself and popped it back in. It's not exactly like it was before but it's close, and they said I can go and have it replaced whenever I want to (but too lazy)
из Johan
Thanks. My service point ordered the keys and replaced them within 2 days for free. Not sure if it was because I've used them so many times in the past or because of some apple policy. Won't touch these buttons again, that's for sure!
из piotr
Could you let me know where I could order 2 arrow keys please. I am in the same boat!
из jason
I think the problem with the arrow block is the system one on the MacBook 16. At the official service center Apple in Russia, the keys do not replacement, but they offer to replace the top case with my money
из Mihail Afonin
Показать 1 больше комментариев
