Released 2017, February Android 6.0.1, up to Android 8.0
5вопросов Показать все
PHONE IS C7 PRO IF ANYONE CAN HELP I DIDNT FND screen is almost dead
i dropped my phone and now the screen is almost black it glows a little bit when i turn it on and then it is very low to be seen
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
This phone screen is very sensitive it may broken and you need to replace it
Был ли этот ответ полезен?
Оценка 0
Hi aamirkahhn,
As Abdul-Jabbar said, it's highly likely the phone's screen has been damaged in the drop and will need to be replaced. iFixit has a video that will show you how to do the job yourself.
Samsung C7 Pro Screen Replacement - iFixit Repair Guide
You can find replacement screens easily online; start with the most popular sites like AliExpress, Amazon or eBay, depending on where you live. A general search for that particular screen will probably also come up with independent sellers as well. Here's one of the first ones that came up on AliExpress that should work.
Original Amoled Lcd For Samsung Galaxy C7 Pro C7010 Lcd Display Touch Screen Digitizer Assembly Replacement For C7 Pro Lcd - Mobile Phone Lcd Screens - AliExpress
Make sure the replacement screen you get comes with adhesive; if it doesn't you'll need to buy a sheet of precut adhesive to resecure the screen when you're done. To be honest, I usually buy more than one, as it's all to easy to misplace it and end up with a tangled mess of glue if you try to pull it back off to get it placed correctly.
Anyway, I hope that tells you what you needed to know; if you have any questions or need any help with the replacement, just reply here and we'll be glad to help.
Good luck and let us know how it goes!
Оценка 0
Добавьте свой ответ
aamirkahhn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 46
