A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
109вопросов Показать все
Are parts of iMac 5k 2019 interchangeable with the 2017 version?
Can I buy the metal housing of a 2017 iMac 5k and use it for a 2019 5k iMac?
What about LCD’s? If my 2019 screen is damaged, can I buy a 2017 screen, with the same model name?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I don’t know of anyone going to this extreme! Apple is good about its parts numbering so parts which carry forward are the same P/N. If there is any differences it gets a new number.
So… looking just at it this way we can see 2019 iMac 27" Retina 5K Rear Housing Unit, Apple P/N 923-03064 Vs 2017 iMac 27" Retina 5K Rear Housing Unit, Apple P/N 923-01666 are different! Are you sure you need a new case? You still need to transfer parts over and there are some sundries that are needed.
As far as the display: 2017 iMac 27" Retina 5K LCD Panel & Front Glass Assembly, Apple P/N 661-07323 Vs 2019 iMac 27" Retina 5K LCD Panel & Front Glass Assembly, Apple P/N 661-12558 again, the part numbers are different!
Был ли этот ответ полезен?
Оценка 1
i found this link re the question : https://witcomputers.com/product/imac-27...
Оценка 0
1 Комментарий:
Apple upgraded the display assembly part with a brighter panel. Both the LCD and the LED backlights where upgraded. Otherwise the part is electrically and mechanically the same.
из
Добавьте свой ответ
Alex222 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 56
За всё время: 1,294
