A question about compatibility between models
I have a 2015 Macbook pro with upper-end i7, full memory, and a good display adapter. Recently some liquid was spilled into the keyboard and now things are beginning to quit, like one of the USB ports for example. The display also has a crack in it. I was wondering if the memory, processor, or display adapter would be compatible with newer MBPro’s? I was thinking about buying a newer model and then upgrading it.
Thanks!
-BW
Update (12/13/2019)
Dan,
Sorry for this late reply. I have health concerns to deal with. Can you still assist me in finding a replacement display? I have a MacBook Pro (Retina, 15-inch, Mid 2015).
Here are the full specs...
Model Name: MacBook Pro
Model Identifier: MacBookPro11,5
Processor Name: Intel Core i7
Processor Speed: 2.8 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Hyper-Threading Technology: Enabled
Memory: 16 GB
Boot ROM Version: 194.0.0.0.0
SMC Version (system): 2.30f2
Serial Number (system): C02QW0WFG8WQ
Thanks!
- Bill
Это хороший вопрос?
3 Комментариев
It seems you picked the wrong reference model, as the Macbook A1534 you chose doesn’t have an i7 processor, nor “ports”, it’s got an Intel M Cpu and a single Usb-C port. However, if you have as I believe a 2015 Macbook Pro 13” , not a single part is compatible with following models, Cpu and Ram are soldered on the logic board, Ssd is different, screen is different, even the charger is different.
из arbaman
Thanks, arbaman. Of course, you are correct. It is an A1398. I had not looked before sending the request. My bad!
из Bill Wilson
@Bill Wilson Not a problem at all. Unfortunately same thing goes with the big guy A1398 too, everything is soldered on the board.
из arbaman
