Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
539вопросов Показать все
iMac 24 2134 play dead but will do a beep every 5 sec when ram is out
My son iMac 24” 2124 die suddenly, when unplugged for a while then plug 1 led will turn on. If pressing on power button will hear fan briefly and led will go out.
I’ve removed the 2 2gb dimm under the screen, then if I keep power button on both led turn on and will get the 1 beep every 5 second like the “no ram” condition.
If I plug back the dimm and to a power on holding the power depressed I will hear sometime the chime, then followed by a single BEEP, then it turn off, no fan, nothing all led are out.
I don’t want to necessarily invest in this machine, so would it be just the ram. Or it’s something deeper?
Thanks for any tips!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Most likely is a failing power supply.
Here’s a video on how to check and/or replace it:
https://www.youtube.com/watch?v=5YvPoMcS...
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Stephane Venne будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 24
