Where can I find bottom screws?
All I am looking for is just one long screw that is suppose to go at the bottom of the unibody macbook pro 13" early 2011. Where can I buy just one screw? Thank you!
Это хороший вопрос?
Это хороший вопрос?
The Genius Bar will probably have some off a junked laptop from a customer. I would try your luck there. If not, they have them in the back.
Был ли этот ответ полезен?
If Nicks answer fails, here's the whole set: MacBook Pro 13" Unibody (Early 2011-Mid 2012) Screw Set
you can put some of the non permanent lock-tight on the screws before you install them
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,700
1 Комментарий
Thanks guys Ill go give it a try!!!
из Louis Lu
