MacBook Air overheating and shutting down - what to do?
I have a Macbook Air (2013).
It is overheating and shutting down.
It seems to shut down at around 100+ degrees C on the cpu (using magican poster to track it, but don’t know how to generate a temperature log file to see the exact temp at shutdown). It gets there when the cpu operates at around 50-60% (again not sure about this because I don’t have a log).
I’ve opened it up and cleaned the fan and exhaust, and there doesn’t seem to be a problem with the thermal paste (the paste that is exposed is still soft, and the exhaust feels as hot as the area around the CPU when rubbing in a high load).
It also seems to run well by forcing the fan to run at max rpm (6500) but don’t want to do that long term.
I’m told that macs are supposed to be able to handle temperature well on their own so I’m wondering whether there’s some other reason, either that the cpu is heating excessively or that the fan isn’t running at the speed necessary to keep it cool.
Any thoughts on this? Or should I just manually increase fan speed whenever I have a high cpu load?
Это хороший вопрос?
2 Комментариев
Has the computer ever come in contact with liquid? have you actually touched the CPU? an easy trick to tell if it is a sensor issue would be to turn it on with the bottom off and touch the CPU. if it is hot, the CPU is failing, if not, it is in fact a sensor issue.
из Tim
Can't vouch for liquid since I pulled this thing out of the e-waste bin. The CPU is definitely running hot--it's almost painful to touch the top of the case right above the CPU (and right above the exhaust).
If CPU overheating is a sign of CPU failure, then yeah I believe it. My "solution" (which I'll post in detail separately) is to stop Turbo Boost and thereby make sure the CPU never runs too much.
из mollie
