Not able to select anything. Not able to put in diagnostic mode.
My electric dyer info:
Sears
Model 110610821187
Ser # mk3401187
Problem is:
Disconnect P3 then reconnect (lower pins first) while pressing cotton cycle button results in dryer responding and starting when start button pressed.
Dryer runs fine until it shuts off, Then I must perform previous action to start again.
Previously replaced the control board but situation unchanged.
Verified:
Power coming in = 240v 120v 120v.
Pin 1 pt 2-5 = 120v.
Update (01/07/2020)
I have been chasing this problem for some time now. My temp solution has been remove P3, then reconnect lower pins first while pressing the cotton button. This seems to work almost every time. We were gone for 6 months and when returned the last time, dryer worked as it should for 2 weeks then had to perform same old routine. Installed a new circuit control board at one time but the problem did not change. Also I cannot place the unit in the diagnostic mode no matter what I try. Voltage entering the dryer are normal (240 & 120 & 120} along with the P1 pins 2 & 5 at 120vac.
Am in need of serious help on this one!
Это хороший вопрос?
