27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Вопросов 20 Показать все
Swap Thunderbolt Display logic board w/ LED Cinema Display board?
Would it be possible to mod a Thunderbolt Display and replace its logic board with a logic board from a LED Cinema Display?
Это хороший вопрос?
Оценка 1
2 Комментариев
Why do you want to downgrade?
из
@danj Currently have 2 Thunderbolt Displays connected to a Mac Mini.
In the process of building a Ryzen based Windows 10 system which does not support Thunderbolt.
The displays are flawless and I can't stomach the ideal of putting them on eBay for $200 when I paid almost $1000 for each.
A video card with DisplayPort would be a lot lot lot cheeper than new monitors.
There are no adaptors or converters for Thunderbolt to HDMI/DVI/DISPLAYPORT
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
No, the two use completely different display panels, and likewise, the control boards are different.
I doubt the internal connectors are even the same.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Hi Alec.
Ugh.
It may not make fiscal since but would a panel and logic board swap work and a little case modification for the IO ports?
из
@smarttiki - Sorry @alecm is right here just not going to work.
Apple’s Thunderbolt Display doesn’t play nice with Mini DisplayPort
What You Need to Know About Thunderbolt 1&2 vs Mini DisplayPort
Now they're maybe a window here! I've not done this but it does appear possible! You need a GPU board that supports TB3/USB-C then use this adapter About the Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter
из
Добавьте свой ответ
smarttiki будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 860
