Is it possible to replace the charging port on my galaxy S10?
My charging port is faulty and I have a lot of experience with iPhone repairs and decent experience with galaxy repairs. I looked at your teardown of the S10. Since the charging port is soldered onto the motherboard, would I need amazing soldering skills to replace it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Yes, it is possible, the microphone is really close, cover it when you are applying heat. You can't see the pins when you are removing and installing the new port, so you need to do a clean job and all pads needs to have the same amount of tin.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jak Esposito будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 464
