Microwave shows door is open when it’s not
I replaced the door switches. Now with the door closed the light stays on and if I try to start. It just says. “Door” and does nothing
Это хороший вопрос?
Это хороший вопрос?
It still thinks that it's open. Check the switch again, make sure everything is wired correctly. Also make sure that whatever contact is being made when the door is being closed is actually being made; if the door closes funny after installing the new switch then you'll need to go back and figure out why it isn't seated all the way in.
Был ли этот ответ полезен?
That was it. A wire was stuck behind the bracket the holds the switch’s.
thank you
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 289
