What materials are needed to seal the iPad 2 front panel?
Это хороший вопрос?
Это хороший вопрос?
http://www.ipadscreenrepair.com/wp-conte...
this will show you where to put the pre-cut 2 sided tape for the ipad 2- very helpful! Good luck!
Был ли этот ответ полезен?
I used 3M double sided tape from Staples and it works.
If there is adhesive left from removing the front panel (assuming that is why you need to seal it?) you can reheat it using a Heat Gun until it gets sticky, then place the front panel back on.
Hope this helps!
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 3,334
