Vizio 42" LED TV released in September 2012.
45вопросов Показать все
Vizio 75” LED TV Screen Issue
Hello,
I’m assuming that my toddler threw something and hit my 75” Vizio LED TV, but I wasn’t in the room at the time. The screen looks like this:
Is this something that can be repaired easily, or should I just be thinking about replacing it? It’s only 10 months old and still under warranty, but that obviously won’t cover the damage if it was my kiddo.
Thanks in advance!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
@scottm219 sorry to be the bearer of bad news. What you have here is a broken panel; no repair possible. A panel that size will most likely cost you more than a new TV (if it is even available). Of course, you can always try and find the same model TV with the same panel but has other issues and harvest the panel from that.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Scott будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 452
