When I turn on my laptop it won't turn on but the light is there
When I turn on my laptop it makes noise around the CD player then it shuts off but the light is still there. What do I do?
Это хороший вопрос?
Это хороший вопрос?
Hi,
What is the model number of the laptop?
It seems as though it is trying to boot from the CD drive that hasn't got a boot disc inserted (is there a disc in there?) and then doesn't boot off the HDD.
Check in BIOS if your HDD is being detected and also what the boot order is for the laptop.
What light is still there?
What OS is installed?
Hi,
Try the following.
Turn off the laptop if it is on and switch off and disconnect the charger from the laptop if it is connected to the laptop.
Once the laptop has completely shutdown, remove the battery from the laptop. (see image below)
Press and hold the laptop’s Power button for 30 seconds and then release the button.
Reconnect the charger to the laptop, switch on the charger and then try to turn on the laptop and check if it starts OK (the battery is still left out at this stage).
If the laptop starts OK allow it to boot all the way to the Windows desktop, allow the HDD activity to settle down i.e. wait about 5 minutes and then shutdown the laptop in the normal manner.
Once the laptop has completely shutdown, switch off and disconnect the charger from the laptop.
Reinsert the battery into the laptop, reconnect and switch on the charger and then try to turn on the laptop.
If it starts OK allow it to boot all the way to the Windows desktop, allow the HDD activity to settle down i.e. wait about 5 minutes and then check the charge status of the battery.
If the battery is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
(click on image to enlarge for better viewing)
Был ли этот ответ полезен?
@jayeff I'm not much of a computer person but I can try to answer these
model: MS-1758
So as for the disk I checked and it looks like something could go in there but I don't know
I don't know the boot order
Blue light
Windows 10
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 15,331
