A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
445вопросов Показать все
Display Colors Changed Suddenly To Weird Tone
Hello all,
First of all, I’ve done all the software related checks (External display, Invert colors check, SVRAM-NVRAM reset, Hard Format etc.). The problem is definitely hardware related.
After 3-4 months past of my warranty end, out of nowhere, my MacBook screen started to display the colors weirdly;
At first, the colors were normal until I open the lid to 30 degrees, but it was going weird if I opened more.
After 1 week like this, the display went completely crazy and showed the colors weirdly the moment I opened the lid.
I brought it to Authorized Apple Service and they checked my device. After that, they called me and told that the problem was not in the flex cables or any other cable from the motherboard side. They suspected that the problem was in the cables from the display area but in cases like this, they directly change the display and charge the customer, according to their procedure.
The funny part is, even they could not define the root cause for this issue. They said that they are also experiencing this issue for the first time.
Actually, I am very disappointed to see that if your warranty has ended, Apple does not do anything if your computer stops working out of the blue.
It is approx. 450€ to change the display here in Turkey, but I am wondering if there are any ways that I could open up the display connection part in my device by myself.
I just want to check the cables (in the display side) and make sure they are connected properly.
Thank you all in advance!
Can
Это хороший вопрос?
Оценка 4
Комментарии:
I have the same problem at recent. Can I ask if you solved the problem? And how much does it cost?This would be a lot of help thank you.
из
@relben_john - Did you review the answer?
I've fixed a few by replacing the display. But you need to check things using an external display.
из
A technician here suggested a flexgate repair would do the trick. Is it possible?
из
@relben_john - FlexGate is a different failure! But the repair is the same replacing the display. Here's more on FlexGate The Design Flaw Behind MacBook Pro’s “Stage Light” Effect
Did you check things using an external display to be sure the issue is within the display and not the logic board?
из
Ive connected it through another monitor to check if its the same, but it works fine from the other screen compared to the screen on the laptop@danj
из
Показать 15 больше комментариев
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sorry to hear you are having a problem with your internal display. Do you see this effect on an external display? If not then the issue is located within the internal displays logic. If you do see the effect on an external display then you have a logic board failure within the GPU logic which drives both internal and external displays.
So let’s talk about the cables a bit as this is more confusing than the older models. In the older design Apple used an eDP from the logic board directly into the lid where the ePD signal was then converted back to the needed raster signals the LCD needs to display the image we call this bit of logic the T-CON. You’ll often find digital TV’s and desktop displays have the same logic board.
So in your case we also have this connection but its a bit different here as unlike the older 2015 MacBook Pro retinal models this cable just moves the signal from the main logic board a few centimeters to the T-CON board which is located on the backside within the main case as you can see here
The bare connector on the T-CON board is the eDP connection. Now keep in mind this cable between the main logic board does not flex! As both boards are anchored to the uppercase. The two cables at each end is what flexes every time you open and close the lid.
While a bit different than the FlexGate issue outlined here: The Design Flaw Behind MacBook Pro’s “Stage Light” Effect is where the backlight cable’s bending got into trouble. Apple fixed the issue by lengthening the cable as described here 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists.
So why does this have a bearing here?? The point is the constant flexing does fatigue the cables so while your issue is very different they are born from the same issue! These display cables are not replaceable as they are part of the LCD panel and are soldered to the T-CON board as you can see here:
So the bottom line here is you can’t fix this without replacing the full display as the iFixit guide goes over MacBook Pro 13" Function Keys 2017 Display Assembly Replacement
Был ли этот ответ полезен?
Оценка 4
Комментарии:
Hey guys,
Unfortunately, the only option is to supply the display from somewhere and replace the display by yourself (Thanks Dan for detailed explanation & links). Considering the cost of new display plus the risk of changing it by my own, I did not go with this way.
After literally not using my computer for almost 1 year, I gave it to Apple for repair in the Netherlands, today. The cost is 580 € + taxes. And the funny part is the new display will be under warrenty only for 3 months! So if anything happens out of the blue again after 3 months, they will ask for money again.
It is still disappointing to hear such cases happening to people around the world.
из
Добавьте свой ответ
can_huner будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 25
За последние 7 дней: 148
За последние 30 дней: 532
За всё время: 16,801
