The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
32вопросов Показать все
Delay in start charging ipad
Recently I bought an iPad mini 5, it works perfectly fine and keep battery very well but when I want to charge it when I plug it into the charger it sometimes take a few seconds (like 4-8 seconds) to start charging and I have to mention that I use Ipad’s original charger and cable and I also used anker power bank also my iPhone charge but I still have this problem.
Any one has experienced it? and anyone knows is it serious problem and is it may damage my iPad?
Это хороший вопрос?
Оценка 2
Добавить комментарий
7 Ответов
Наиболее полезный ответ
Exact same issue here on the iPad Pro 2020: can vary between 10 seconds to over a minute! And that’s with the official USB-C charging cable and fast-charge plug that came with the device
Curiously, using an old iPhone adaptor and USB to USB-C starts charging the same device immediately
And likewise: the official cable and charger are recognised immediately if the unit is powered off
Bizarre, very basic, issue
Был ли этот ответ полезен?
Оценка 1
I also have this problem, I think it’s an issue in iOS/PadOS as I’ve seen iPhones also do this is some versions of iOS.
Оценка 0
I am currently going through this issue. I have tested on Apple branded and other brands of charging wires and ports but issue remains. I’ve contacted Apple and I got my replacement today. Issue is also on the replacement.
Оценка 0
1 Комментарий:
Maybe its an issue with many ipad minis, mine does the same
из
My new ipad mini is always have this same issue :( whats wrong :( do you think this is an ios problem?
Оценка 0
My Ipad mini 5 also has the same problem. Everything is perfectly fine but still it is anoying
Оценка 0
Mine also does the same sometimes it takes 15 seconds, no delays when it’s powered off though
Оценка 0
You should turn off your device before start charging..
Оценка 0
Добавьте свой ответ
navid arbab будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 2,194
