Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
How to fix baseband error iPhone 6 but no original baseband IC
hi there
i have some problem with my current iphone 6
i already bought secondhand iphone 6 with baseband issue (no imei shown) in activation mode so it can’t be activated because no imei
now i already taken apart my phone and it has no Baseband IC (some of the solder pin are missing)
i already ask some phone repair shop that they can’t do repair because of missing baseband IC
but i’m just curious, can it be repaired ? for example buy another baseband IC and solder it to the mainboard ?
also if it can be done, are there required special tool to re-program baseband IC ?
thankyou for your answer
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Baseband chip is paired with all major chips in the phone and encrypted. It is not possible to reverse this encryption.
There are baseband EEPROM chip reprogramming processes, but that only works if good data from the EEPROM chip is read out first or damage to the data is limited and logical error recovery possible.
If the chip is missing altogether, no fix.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Erik giovani будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 1,279
