You might want to try a new Lightning Port Flex (or one that is known-good) to see if that solves the problem. If that doesn’t work, then consider the following suggestions.
Start by testing a bare-bones setup. Disconnect the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex. Now re-connect the battery; you should only have the battery and Lightning Dock flex (new or known-good) connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not boot, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair. Sometimes the fix can be straightforward (i.e. a blown filter) and relatively economical.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
1 Комментарий
Hello
I have an iphone xs
When using snapchat telegram or facebook the phone gets too hot. Even while playing some games the phone becomes extremely hot and lags constantly.
I checked panic log and it says
"i2c3::_runInterruptMode Timed out waiting for interrupt; last write status 00200118 int shadow 00210100 xfer 00000000 fifo 00000022 for device display-eeprom\"
Can anyone tell me what that means.
Thanks
из Jaj Sob
