Use iMac 27" (Late 2012) 2546 internals in a PC case
Hi,
I have a iMac 27” (Late 2012) model, but screen cracked. Don’t want to invest in the whole LCD unit replacement which can’t be reused down the road. So I want take the internals out and put it in a separate PC case, and connect it to a separate monitor.
I went online and did some research and found that, this might be possible, but the main issue is the LCD thermal sensor. I need to find a way to either disable it or trick it into thinking that the LCD thermal is ok. Otherwise, the system would put the fan to max speed and throttle the CPU severely to prevent overheating. Is there any suggestion to crack this issue?
Thanks
Это хороший вопрос?
1 Комментарий
@goldenbear let's see if we can help you. The sensor is really nothing more than a transistor that measure this. We would need your board to see if it can be bypassed
For further reference on this question 2n3904, 2n4401
из oldturkey03
