Серийный номер пропал из системы MacBook Pro 15'' (Retina, mid 2014)
Russian: Всем доброго дня!
Позавчера мне прилетела обнова 10.15.3, которая сама начала устанавливаться. Я прервал обновление принудительным выключением ноутбука.
После этого, включив его, я не обнаружил серийного номера в свойствах Mac. В “Отчете об устройстве” его также не было. По запросу в Терминале его также нет…
Сам серийник мне известен, он есть на нижней крышке, и еще у меня он сохранился на фото. Но прописать-то его как??
Нарыл софт “Blank Board Serialyzer”, но, похоже он не работает с Macbook, начиная с late 2013 и выше (в том числе и с моим).
Не знаю, куда копать… паять плату совсем не хочется!
Возможно кто-то сталкивался с такой проблемой?
Good day to all!
The day before yesterday, I received an update 10.15.3, which started installing itself. I interrupted the update by forcibly turning off the laptop.
After that, when I turned it on, I didn't find the serial number in the Mac properties. It wasn't in the device Report either. The serial number is not displayed even on request in the Terminal.
The serial number itself is known to me, it is on the bottom cover, and I still have it preserved in the photo. But how can I prescribe it??
I dug up the software " Blank Board Serial zar”, but it seems that it does not work with Macbook starting from late 2013 and higher (including mine).
I don't know where to dig... I don't want to solder the Board at all!
Perhaps someone faced such a problem?
English: Good day to all!
The day before yesterday I arrived update 10.15.3, which itself began to be installed. I interrupted the update by forcibly turning off the laptop.
After that, turning it on, I did not find the serial number in the properties of the Mac. In the “Device Report” it was not there either. On request, it is also not available in the Terminal ...
I myself know the serial, it is on the bottom cover, and I still have it in the photo. But how to register it ??
Naryl software “Blank Board Serialyzer”, but it does not seem to work with a Macbook, starting in late 2013 and above (including mine).
I don’t know where to dig ... I don’t want to solder the board at all!
Perhaps someone has encountered such a problem?
Это хороший вопрос?
