The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100вопросов Показать все
Why won't my tablet turn on?
I have replaced - battery, main mother board, left speaker with power strip.
I put new battery in & used it until it died. Charged it over night & when i unplugged it, it said 100% charged. Unplugged it & tried to turn it on but wont power on. Theres no noise, no nothing. I also tried holding the power & volumn buttons down. Ive taken it apart & receded everything. Took off button & tried to start it manually. What else can i try?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@mamabearcat just to make sure I understand you correctly, it worked without any problem for as long as the battery was charged/ After that it said the battery was at 100% but did no longer have a sign of life. You said you replaced the motherboard but did you replace the charge port. This really sounds like your battery is not charging but you are getting a wrong fuel gauge read. If it would be anything related to the motherboard, a new board should have fixed that. Galaxy Tab S 10.5 Charge port Replacement
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thank you for your advice. I will order that & give it a try. It still doesn't make sense why it charged though. I would think it would be the opposite & not charge . The reading on the tab. did show the correct amount of charge. When i received the new battery it was at 54%, i watched it go down until it died & plugged it in over night & in the morning it said 100 %. But wouldnt turn on or even show that the battery was charged after i unplugged it. I would appreciate an easier explanation if you don't mind. I will still take your advice though, its the only thing that i havn't tried.
из
Hi im still having trouble. I re- ordered a NEW LEFT SPEAKER W/ POWER BUTTON, NEW CHARGING PORT W/ RIBBON, & NEW BATTERY! Rem. the mother b. Is new also. Still won't turn on or even take a chg. When u 1st plug in, u hear a little noise & vibration like it's getting the elec. But no battery or circle that says it's charging comes up. Everything is brand new, I DON'T GET IT! PLZ HELP! if you would like to talk on phone let me know with your num. or ask for mine. Thanku
из
Добавьте свой ответ
Shari Dixon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 314
