Модель A1312 / Середина 2010 г. / 3,2 ГГц Core i3 или 2,8 и 3,6 ГГц Core i5, или 2,93 ГГц Core i7, ID iMac11,3
iMac won't turn on after soldering the display connector back.
One day, I tried to upgrade the SSD by removing the LCD display, but unfortunately the display connector was broken and falling off, so I bought a new connector, and try to soldering it back to logic board (disassemble the logic board and do the soldering job), after it is done, assemble the logic board with all wires connected and turn on the iMac, but no image shows on screen,
I then tried to connect my iMac with an external monitor, it works fine, which means the connector may not be soldered correctly or properly, so, I performed the soldering process again (but this time, I did have the logic board stayed with iMac with all wires connected, and of course the power cable is disconnected), but after that, the iMac won’t power up at all, nothing happened by pressing the power button, I tried all possible solutions such as disconnect the power cable for 10 seconds, then put it back, or remove the RAM, etc. but no luck.
Does it indicate the logic board is gone completely? Or is there some trick I should try?
Any thoughts?
Thanks,
Update (02/28/2020)
Это хороший вопрос?
Счет 0
6 Комментариев:
@hru1207 post some pictures of the soldered connector and the board as well. That way we can see what you see. Добавление изображений к существующему вопросу
из
Sorry, it took me a while to figure out how to paste the images here :). The first two is what it is now, and the 3rd one is what the old connector falls off from the logic board. Let me know if you can see it this time.
Thanks again,
Alex
из
@hru1207 - Sadly you did jump a few of the pins when you soldered. These are tricky connectors! You'll need to carefully remove the connector without lifting any of the pads. Then you'll also need to clean the solder off the connector. I think you'll need to find someone with a smaller tipped soldering iron or you might what to find someone with good soldering skills.
из
Thanks Dan, and I will try it once more.
из
Using your last image as a reference we can see there is very little solder needed to connect the pins to the logic board pads. Makes sure you use some solder-wick to clean the pins and pads down to smooth metal. Use isopropyl alcohol to clean off the old flux and other junk. Place a bit of solder on one of the end pins using one hand to hold the connector in place use the small tipped iron to heat this one pin so the solder melts anchoring the connector in place. Now go to the other side and do the same on that pin now solder the larger bases down. Once they are soldered slowly do each of the other pins. Remember its not the quantity of solder thats important its the electrical connection.
из
Показать ещё 1 комментарий
Добавить комментарий
4 Ответов
The issue you describe sounds like a P.O.S.T. failure. When you first start a computer whether it's a smartphone or a super computer and everything in between runs a Power On Self Test. This is the first program that every computer runs before the operating system is loaded. If there is a failure the computer will not boot. The P.O.S.T. is controlled by the BIOS. Chance are your BIOS cant' see the drive. The easy way to resolve this issue is to boot into your BIOS set-up utility and change your boot order manually.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
The iMac won’t turn on at all, no sound or fans run, etc. It just nothing happened after pressing the power button. Is this also related to P.O.S.T?
из
@laurayuan - POST still involves the display, as Alex is not able to get the internal display working its clearly not a POST issue.
из
@hru1207 - It does sound like you have a bridged solder joint on the connector. Let’s take it off again and check the solder pads. Take a few pics what you have now and again after removal (cleaned) Добавление изображений к существующему вопросу
Also, locate the onboard diagnostic LED’s hidden under the tape
Счет 0
4 Комментариев:
Thanks Dan, I will try to upload some pictures today.
из
Hi Dan,
I just uploaded some pictures to my original questions, I appreciate if you can take a look there.
Thanks again!
Alex
из
@hru1207 - Where did you paste them?
из
Hey Dan,
Did you see the pictures now?
Thanks,
Alex
из
@hru1207 remove the connector once more. You have too many solder bridges and looks like poor connections on some contacts. Clean the pads with flux and solder-braid. After that try to solder the connector with a technique called drag soldering to attach a new connector. Right now every attempt to start your computer runs a chance of shortening power-rails and creating more damage
Счет 0
1 Комментарий:
Thanks for your feedback and comments, and I will try it again.
из
Where can I buy the display conector? And is it worth fixing it?
Счет 0
Добавьте свой ответ
Alex буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 502
