The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
73вопросов Показать все
Memory card is "removed" when I'm using it normally
When I use my PS Vita it'll freeze and shut itself off saying the memory card was removed and restart itself. Some times I have to restart it multiple times for everything to be restored.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi ernesto25
What is your memory card information?
Did you use any adapter or etc to convert your memory card? like sd card to vita memory card?
try testing with another memory card and observe the results.
sometimes the memory card can either fail or corrupted.
if it is still under warranty, you can send it for a check or replacement.
another possibility if memory card has been removed from the vita, internal memory reader pins might be loosen, cold solders… etc which might need to either replaced or calibrated.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
ernesto25 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 1,033
