iMac Intel 27" EMC2309 Core 2 Duo Questions.
Hi,
I have recently picked up one of these old beasts and want to do a bit of a project on it to see if I can get her going and if so how fast I can make the speeds.
This post will pose quite a few questions
So to begin I plug this Mac in and power it on and hear a few sounds and vibrating “brrr” kind’ve sound and can hear a few things spinning up. I don’t get a Chime and the screen remains black. The fans are quiet but do turn as I get cool air coming out when I put my hand at the top.
So if anybody could offer some trouble shooting steps about problem solving the boot I’d appreciate it.
I’ve heard of resetting the NVRAM, PRAM. I haven’t done these but I do plan to. I believe I have reset the SMC.
Since I have done research and have found that the logic board is potentially the reason I can’t get it to boot. I also realize that I cannot upgrade to the iSeries processor and to do this I must change the logic board to one of the newer A1312 boards. But first I must get it running to see what needs fixed and what doesn’t.
I have been doing quite a bit of research regarding an old mac I picked up and have discovered the only way of unlocking some more CPU power is to change the logic board to allow for Intel iSeries processors.
My question is has anyone actually successfully switched to one of the newer A1312 logic boards? If so was there any hiccups or quite severe drawbacks.
Secondly would I need to get a new GPU? or would the one out of my current EMC2309 iMac be compatible?
Same as the ram is it plug and play compatible also between the logic boards.
A good explanation of what isn’t compatible would be greatly appreciated. And any links to in depth guides on the process as I couldn’t find any.
Also, the logic board I’m looking at swapping with is from this model iMac Here
TL;DR : I have a 2009 27” A1312 iMac and it doesn’t start. I have reset the SMC and plan to do the NVRAM and PRAM. I need some steps about howto get it going as I’m familiar with Windows machines but not Apple machines but am eager to learn. If the logic board is broken I want to upgrade it to one of the later A1312 boards. First I must get it going.
Thanks,
Jacob
Update (03/16/2020)
@danj Hi Dan! I’m back having replaced the logic board with the iSeries one you suggested and an Intel i7 processor. I got the parts really cheap as the guy who sold it said the CPU fan ran at full speed and it was given to him like that so he sold it for parts.
Where would I start troubleshooting for something like this? The CPU fan sensor is plugged in correctly and in MacFanControl it reads at 0rpm it will be silent for about 8 minutes then when the processor gets warm the fan will go at full speed.
Thanks,
Jacob
Это хороший вопрос?
8 Комментариев
I'm not sure if your better off here ;-{
Do you know how to read a schematic and boardview? Do you have a DVM with the needed smaller probes? Even still you'll likely need to replace a component or two so you'll need a good soldering iron and you may need a re-work staton.
Do you know someone local that can help you?
из Dan
@danj hi dan, due to the COVID situation I’ve left the city and my apartment to go stay with my parents. Bonus!! My soldering gear is there so I’ll be able to fix this logic board. Where will I start?
из Jacob Hunter
I've explained as best I can in my answer. You'll need to get the needed logic board for your i7 CPU, and then if you are trying to fix your damaged board you'll need to get the connector. Unless you are skilled with soldering you could end up with bridged pins with solder.
из Dan
@danj I just had a thought, since I am planning to remove the ODD could I just reroute and maybe extend the CPU fan to plug into the ODD fan connector then use a piece of software like macs fan control and set the fan speed to be based on the sensor value of CPU Core 1 or 2?
Just a thought. Quite a work around but it seems possible to me
из Jacob Hunter
I'm totally lost here??? Where are you going? I thought you have lined up a new logic board, didn't you?
из Dan
Показать 3 больше комментариев
