Clothes dryer repair and support guides.
871вопросов Показать все
Dryer won't continue through cycles and it is producing heat?
My dryer will start and dry and the clothes get hot it just won't continue through cycles to turn off its self it just keeps running until I open the door or then the knob my self. How do I get it to continue through cycles and turn off it does it both on automatic dry and timed dry
Это хороший вопрос?
Оценка 0
2 Комментариев
sean barnhouse what make and exact model number is your dryer?
из
Amana mod NED4655EW1
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Solution 1:
Air Flow Problem
If the vent is clogged or partially clogged, it will restrict the airflow through the dryer, substantially increasing the drying time. To ensure proper dryer performance, you should clean your dryer’s venting system at least once per year.
Solution 2:
Blower Wheel
The blower wheel draws air through the dryer and pushes the air out the vent. Clumps of lint, socks, and small articles of clothing can escape the lint filter and get caught in the blower wheel. In addition, the blower wheel sleeve can wear out, allowing the blower wheel to wobble on the motor shaft. If the blower wheel is obstructed or defective, it may take too long to dry clothes. To determine if the blower wheel is working properly, remove the dryer vent and assess the strength of the air flow. If the air flow is weak, check the blower wheel for obstructions. If no obstructions are present, try rotating the blower wheel by hand. If the blower wheel wobbles as it turns, replace it.
Solution 3:
Heating Element
The heating element warms the air before the air enters the dryer drum. Over time, the heating element can burn out. If the heating element isn’t working, the clothes will take substantially longer to dry. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Solution 4:
Cycling Thermostat
The cycling thermostat cycles the heat on and off to regulate the air temperature. If the cycling thermostat is defective, the dryer will not heat. However, this is rarely the case. Before replacing the cycling thermostat check all the more commonly defective parts. If you have determined that all of the other components are working properly, test the thermostat by using a multimeter to test for continuity. If the thermostat does not have continuity, replace it.
Solution 5:
Timer
Mechanical timers have a motor on them like a clock that rotates the timer down to the off position on the control panel. If the motor goes bad on the timer it will not move when set to a timed dry cycle and the dryer won’t stop.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
sean barnhouse будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 109
